Hp tuner use
kwamonster
Hp tuner use
My question is if I have my diablosport tune loaded on my camaro, could I stilll hook my car up to hp tuners to have cat codes disabled?
Re: Hp tuner use
if you do that, then the last tune written by the trinity will not match what's in the car, so then the trinity will be locked on ya, and you won't be able to use the trinity at all to tune the car..
kwamonster
Re: Hp tuner use
Thank you for your answer. So what would happen if I were to return to stock then tune out the cats? Then hook my trinity back up. My guess is the hp tuners file would be over written. Is that correct?
DiabloMatt
Re: Hp tuner use
kwamonster wrote:Thank you for your answer. So what would happen if I were to return to stock then tune out the cats? Then hook my trinity back up. My guess is the hp tuners file would be over written. Is that correct?
that is correct.
