Need Help!! Fan is always on!!
cue244
Post by cue244 »
I set my fan to these settings: H-226, M-226, and L-203. Last night I drove to the gas station about three miles away and my fan kicked on!! It was 7 degrees outside. My fan is always on. I am not sure if it effects gas and power.
My fan never was on before I installed the Predator. I am not sure what to try on settings. Thanks.
RE: Need Help!! Fan is always on!!
It does not affect gas or power.
Sounds like you did not reinstall the tune after making these changes maybe?
cue244
Post by cue244 »
I tried to reinstall it again at those settings and same thing. Maybe if I try raising the temps a little that might help?? Also Do I need to set the AC off fan temps?
johan
Post by johan »
Are you using the latest revision, the earlier revs had this issue.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
