Page 1 of 2
Dataviewer still refuses to work...
Posted: Wed Jan 23, 2008 4:20 pm
by houseofpower
This is an on going problem with your dataviewer. Plug predator into cars OBDII port, connect via USB to serial, open up program and start. Yes infrequently used PID's is enabled. It takes sometimes twenty attempts to do get all the PID's up. Regardless of laptops the problem is still there. Some cars I have no problem and some I do. Seems that there could be an interface problem between 2005 vehicles and perhaps late 2006. Because some early 2006's exhibit the same problem.
1) The acquiring vehicle identification takes almost 3 minutes to complete.
2) Once it's finished...
A. It only shows PID's & DMR's in the tree
B. It show's PID's & DMR's with a small portion of available PID's from the vehicle.
Re: Dataviewer still refuses to work...
Posted: Wed Jan 23, 2008 4:34 pm
by johnc
houseofpower wrote:It takes sometimes twenty attempts to do get all the PID's up.
Are you using the latest version (3.1.5.2) ? You never answered me in the other thread you started.
If this version does not help you, and you have indeed tried this from multiple laptops, then I recommend trying a new serial cable.
houseofpower wrote:A. It only shows PID's & DMR's in the tree
The tree represents all the
available PIDs and DMRs. The PIDs and DMRs
you will be recording appear on the charts and gauges to the right.
You ADD and REMOVE PIDs and DMRs from the charts and gauges by selecting them in the tree. Please review the instructions on the info tab. These instructions are also available in the Help file. Right click on a PID or DMR in the tree, select "Add Digital Gauge", etc.
Posted: Wed Jan 23, 2008 5:00 pm
by houseofpower
In that thread I replied back with using 3.5.10
I have used your supplied cable, and I have tried using two other types of data cables that I use with other software.
The tree represents all the available PIDs and DMRs. The PIDs and DMRs you will be recording appear on the charts and gauges to the right.
I know how it works. I have a 2006 charger SRT 8 here as well and I can hook up fine to that car with the Dataviewer. It's apparent that it does not like 2005 vehicles.
Posted: Wed Jan 23, 2008 5:19 pm
by houseofpower
SS
Posted: Wed Jan 23, 2008 5:31 pm
by houseofpower
Well?
Posted: Wed Jan 23, 2008 5:36 pm
by johnc
3.1.6.2 is the latest version. You are using 3.1.5.10. You should upgrade that first.
As for your screen shot above, click on View -> Show Vehicle Information and give me a screen shot of that dialog.
Posted: Wed Jan 23, 2008 5:41 pm
by houseofpower
GG, you send out a new version every week? How about making it perhaps auto detect for updates automatically? Downloading new version, I'll give you a heads up in 5 min.
Posted: Wed Jan 23, 2008 5:48 pm
by johnc
Most of the time releases are in support of new Predators, or include updates to the database such as additional DMRs. This latest release, though, had some changes to the communications layer. That's why it is important for you to give it a whirl.
Posted: Wed Jan 23, 2008 5:51 pm
by houseofpower
No Good same problem.
Posted: Wed Jan 23, 2008 5:55 pm
by johnc
If you didn't already, please click on the blue vehicle button to rescan your PIDs.
Posted: Wed Jan 23, 2008 5:56 pm
by johnc
And don't forget this request:
johnc wrote:As for your screen shot above, click on View -> Show Vehicle Information and give me a screen shot of that dialog.
Posted: Wed Jan 23, 2008 5:57 pm
by johnc
Well?
Posted: Wed Jan 23, 2008 5:58 pm
by houseofpower
Already did that. Still nothing.
Posted: Wed Jan 23, 2008 6:00 pm
by johnc
How about the View -> Show Vehicle Info?
Posted: Wed Jan 23, 2008 6:07 pm
by johnc
If you would, after you have retrieved the Show Vehicle Info, close the DataViewer and then email me your runtime.txt file. On Windows XP you should find this file under C:\Program Files\Common Files\DiabloSport\DataViewer.
