Newbie question
Posted: Sun Jan 27, 2008 6:06 am
by Illss1
I see on this : Predator Updates Last Update Revision File
Release 18 (current)(Idle surge fix, Autostick fix for 06-07 5.7L,Autstick feature removed from 07 SRT8, Live data export fix, support for 06 jeep srt8(export),MBT spark adjustment added, knock sensor parameter removed) 11-19-07 r18 u7135-8r18 (crom) 864k
Release 17 Support for, early05,export and police calids added. Live Data added.) 10-30-07 r17
Test 16a(Fix for quick adjust issues in r16, except autostick disable in 07srt8) 10-17-07 t16a
Release 16 (EGR/MDS/Rear 02 disable,low throttle response improvement,wot fuel adjust fix) 10-17-07 r16
Release 14 (Release) 09-28-07 r14
MY PREDATOR SAYS : Predator v.8r14 ......... my car is an 06 CSRT8 an i'm going over threads trying to understand this stuff because these 16 an up doesnt fix anything on a 06 CSRT8 right ? Otherwise it would say correct ? SO DO I OR SHOULD I HAVE TO DOWNLOAD THIS 8R18 ?[/b]
RE: Newbie question
Posted: Sun Jan 27, 2008 6:12 am
by Illss1
Also one last question how do i UNALTER a can tune ? I altered a setting an i want to unalter it to a untouched can tune .
RE: Newbie question
Posted: Sun Jan 27, 2008 2:49 pm
by Illss1
RE: Newbie question
Posted: Sun Jan 27, 2008 3:40 pm
by Mike_Levy
Go into Quick Adjust, then Restore Quick Adjust, the Restore Defaults. That will put it back to the original settings.
Re: RE: Newbie question
Posted: Sun Jan 27, 2008 10:02 pm
by Illss1
Mike_Levy wrote:Go into Quick Adjust, then Restore Quick Adjust, the Restore Defaults. That will put it back to the original settings.
Thanks cool but what about the first question in post no.1?
RE: Re: RE: Newbie question
Posted: Mon Jan 28, 2008 12:12 am
by Mike_Levy
I would download the update. It improves the Data logging, which in my opinion is a very important feature. Thats actually the only reason I'm still using the later version. I liked 16a the best, but am dealing with 18 to keep the logging updates and other stuff.
You have 14, which is old and doesn't have the better features. Go to at least 16a, if you can find it, if not all the way to 18.
