2012 Silverado 6.2 - Door Lock/Key Fob
Lanebalfour
Post by Lanebalfour »
After installing my Diablo Trinity, my key fob or RKE will not work I have Reyes both sets and and still nothing. I was wondering if anyone else has had this problem and has an answer.
Re: 2012 Silverado 6.2 - Door Lock/Key Fob
the trinity may cause radio signal interference with the remote receiver.. don't leave the trinity connected to the obd port all the time.. when you get out of the vehicle, disconnect the trinity.. that's the only fix/solution.
Lanebalfour
Okay, so I tryed that and still nothing, even tryed uninstalling and re installing and nope.
Thanks again
so, they dont work after restoring the stock tune and removing the tuner?
Lanebalfour
Correct.
As well as my "tire monitoring system" had failed. All that same after after installed the tuner at the start.
we dont have any control over the BCM which controls both of those systems, may be time for the dealer to look at it.
Lanebalfour
Could've been a coincidence that it happened after installing the tuner.
Return to “Trinity GM Gas”
