Can't update intune
Can't update intune
I recently removed the tune from my 06 srt8 Chrysler 300 so that I could install a tune in my 04 dodge ram 1500. When I tried to tune my truck the intune told me it would require an update to do so. I have attempted to update the intune with my Windows 8 pc several times now, and it always ends with the same message on my intune reading "Failed to install Group_Update.itfg"
Re: Can't update intune
please post the info file fromt he intune drive.
<tool_info>
<main full_version='InTune-1r03m 07/22/2013 02:01:08 PM' sw_rev='1r03m' svn='6444'/>
<registration sn='IIRFTB8-5' status='1'/>
<cal_id PCM='56029161AF' CM1='56028810AD'/>
<restore id='0' vin='1D7HU18D34J245143' bc='0'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01c'/>
<db mfr='DCX' tune='1r01b' pid='1r01a'/>
<db mfr='FORD' tune='unknown' pid='1r01b'/>
<db mfr='GM' tune='1r01z' pid='1r01a'/>
<license avail='1' tuned='0'/>
<unsupported calid='56029161AF' vin='1D7HU18D34J245143' oem='DCX'/>
<updates count='5'/>
<oem tool_oem='DIABLO'/>
</tool_info>
</tool_info>
save this to the tool then run after it imports it run the updater again.
- intune-1r03y.itf
- (1.82 MiB) Downloaded 347 times
I loaded the file into my intune, and was able to complete the update but, when I tried to tune my truck it said that calibration update had failed and put my intune into recovery mode.
<tool_info>
<main full_version='InTune-1r04i 08/03/2015 01:32:36 PM' sw_rev='1r04i' svn='8521'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01e'/>
<db mfr='DCX' tune='1r01f' pid='1r01b'/>
<db mfr='FORD' tune='1r02e' pid='1r01b'/>
<db mfr='GM' tune='1r02r' pid='1r01a'/>
<updates count='7'/>
<reg reg='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'/>
</tool_info>
<tool_info>
</tool_info>
what happens when you run the recovery mode?
Does the vehicle start and run?
Daniel Gomberg
Tech Support
Phone: (561)-908-0040
Fax: (561) 431-0429
Tech Support
Fax: (561) 431-0429
Duaranged21
Having the same issue on my intune. Message states " The current firmware revision (1r03r) cannot be replaced by the firmware package within GRoup_Update_4. Just purchased it this weekend.
save this ot the intune dirve, let it import, then run the updater again.Duaranged21 wrote:Having the same issue on my intune. Message states " The current firmware revision (1r03r) cannot be replaced by the firmware package within GRoup_Update_4. Just purchased it this weekend.
- intune-1r03y.itf
- (1.82 MiB) Downloaded 334 times
