Any PID to see the actual (not commanded) AFR ?
AlexIV
Post by AlexIV »
Hi,
Please advice what PID I have to select to see and log actual AFR at O2 sensors 1 (bank 1 and 2)
Thanks in advance.
Re: Any PID to see the actual (not commanded) AFR ?
most vehicles do not report actual AFR, what vehicle is it?
AlexIV
Post by AlexIV »
mikel wrote:most vehicles do not report actual AFR, what vehicle is it?
JGC 2012 5,7
no, you need a wideband sensor to see the actual AFR.
AlexIV
Post by AlexIV »
mikel wrote:no, you need a wideband sensor to see the actual AFR.
Thanks, because I do worry. When I see the picture with actually flat desired AFR and knock retards when engine goes to load ... I do worry.
During the whole log (run) I saw only one moment where AFR went to reach.
Please see the pics just on the fly ( flat AFR)
