Fans on always
Posted: Wed Jan 30, 2008 7:01 pm
by HemiNewbie
2007 Magnum 5.7
Put the new rev 93 oct tune in for the first time. The engine fans are on all the time. I'm at 5000 ft and it's 20 degrees out side. I really doubt I need the fans. Wazup?
RE: Fans on always
Posted: Thu Jan 31, 2008 11:51 am
Try the latest revision, it has the fan temps back to stock.
fans on
Posted: Thu Jan 31, 2008 2:52 pm
by HemiNewbie
Mike I downloaded and installed the latest version
Dale
RE: fans on
Posted: Fri Feb 01, 2008 8:27 pm
by cue244
I had the same problem. I am working the fire station today but in the morning I will post my fan settings. Since I have changed them, my fan doesn't kick on anymore.
RE: fans on
Posted: Sat Feb 02, 2008 2:08 pm
by cue244
Here are my fan settings:
Low- 217.39 Med- 226.39 High- 226.39
A/C Off
High MPH HS - 226.39
High MPH LS - 217.39
High MPH MS - 226.39
Low MPH HS - 228.39
Low MPH LS - 217.39
Low MPH MS - 226.39
Posted: Sun Feb 10, 2008 4:42 am
by ADSRT
Get a 180 Tstat it will take care of everything.
Posted: Mon Feb 18, 2008 8:28 pm
by joeyclutch
where should my fan setting be i have 06 srt8 with a 180 t stat cai93 tune
Posted: Tue Feb 19, 2008 9:17 pm
by DESIRAY
joeyclutch wrote:where should my fan setting be i have 06 srt8 with a 180 t stat cai93 tune
I'm running a 180*F t-stat that indicates coolant temps of 185-188*F in the EVIC. According to DS there is a 10*F range between the fan on temperature and the fan off temperature, so to keep the fans from running continuously I'm running my fans @ HS = MS = 207, and LS = 197. I've seen the LS shut off at 189*F.
Posted: Tue Feb 19, 2008 9:40 pm
by joeyclutch
thank you I went to adjust them and notice that I had them set at 183.99 for all of them so I did raise them up and it solved it thanks again
Posted: Tue Feb 19, 2008 11:17 pm
by jferraino
Good information here. What would you folks suggest if your running a 170 tstat?? thx
