Making Trinity to read boost in psi
Posted: Tue Jan 19, 2016 2:50 pm
by retromusclecar
How do I configure the trinity to read boost in psi?
Re: Making Trinity to read boost in psi
Posted: Thu Jan 21, 2016 4:22 pm
in logging menu click on the boost gauge and select change display units, then save the layout with a new name and it will show up in that layout as psi.
Posted: Thu Jan 21, 2016 4:58 pm
by retromusclecar
mikel wrote:in logging menu click on the boost gauge and select change display units, then save the layout with a new name and it will show up in that layout as psi.
Thanks got that done, but it's not reading anything do I need to add an external sensor? Vortech super charger.
Posted: Thu Jan 21, 2016 5:27 pm
no...did you save the layout?
Posted: Thu Jan 21, 2016 10:02 pm
by retromusclecar
mikel wrote:no...did you save the layout?
Layout? gauge layout right? Went out and did a new layout, Boost, AFR, MAP, Intake temp F, saved and put in monitoring and the boost still doesn't work.
Posted: Mon Jan 25, 2016 5:33 pm
by retromusclecar
Guy's what else can you suggest, are there certain PID's that need to be with the boost to make it work, like a special layout?
Posted: Mon Jan 25, 2016 5:42 pm
there is a walk through in the manual, but you click on the gauge and select change display units, select pi, then when its done, click the red X in the corner and choose to save the layout with a new name.
Posted: Mon Jan 25, 2016 6:09 pm
by retromusclecar
Ok setup a layout with Boost, OBDII MAP, OBDII Baro, engine RPM I got the boost to read for a split second, then nothing.
by retromusclecar
mikel wrote:there is a walk through in the manual, but you click on the gauge and select change display units, select pi, then when its done, click the red X in the corner and choose to save the layout with a new name.
Yes I did all that
Posted: Tue Jan 26, 2016 3:41 pm
by retromusclecar
Yes I did all that
Do you think an update is needed?
Posted: Tue Jan 26, 2016 3:50 pm
What version is on the tool currently?
This has worked for some time now....
Posted: Tue Feb 16, 2016 5:25 pm
by retromusclecar
The trinity is not even a year old so It should be good, if you were to setup a page to read boost what pids would have to use with the boost pid in order for it to read?
