2014 GMC Sierra warranty
Posted: Thu Jan 21, 2016 11:15 pm
by Tschumacher359
Soooo I have a 2014 GMC Sierra reg cab 5.3 flex fuel and am running e85 and planning on doing long tubes. The trinity interests me because I'll be able to tune for these mods (correct me if I'm wrong) but I am extremely concerned about my warranty. I only have 15000 miles.
Will the tuner void my warranty? I've read it won't cause u just tune back to stock before u get warranty work but haven't read anything on the 14+ silverados and sierras.
Re: 2014 GMC Sierra warranty
Posted: Fri Jan 22, 2016 9:43 am
by 06MonteSS
as long as you remember to restore the original backup stock tune to the truck first before going to a dealer, you'll be fine.. they can't tell what was changed..
BUT..
you're in a catch-22 if you do long tube headers.. because you will HAVE to have a tune in order to have necessary trouble codes disabled, fueling adjusted correctly, etc.. and if you don't have a tune, you will be throwing trouble codes and the Check Engine light will be on..
so if you restore stock tune while having headers, and you go to a dealer, you will have codes/CEL on when you take it to them.. so you'd need to have the tune installed..
Posted: Fri Jan 22, 2016 4:08 pm
by Tschumacher359
06MonteSS wrote:as long as you remember to restore the original backup stock tune to the truck first before going to a dealer, you'll be fine.. they can't tell what was changed..
BUT..
Yeah that's what I was assuming....cause I believe I have to delete the o2 sensor behind the cat as well so that would throw the trouble code as well. But with this tuner could I delete the sensor or tune it out?
Posted: Sat Jan 23, 2016 8:18 am
by 06MonteSS
you would have to get a custom tune done for it in order to have the necessary trouble codes disabled..
http://www.diablewtune.com/package_deals.html
Posted: Sat Jan 23, 2016 9:04 pm
by Tschumacher359
Actually I was mistaken. I don't have to delete any o2 just need to do the normal tune shit. Can I do so with the trinity??
Posted: Sat Jan 23, 2016 11:01 pm
by 06MonteSS
If you are doing headers and high-flow or no cats, you will HAVE to get a custom tune in order to have the necessary trouble codes and related items disabled. You can not do that with the tool itself.
If you are not doing headers, and are keeping the stock cats on the truck, then sure, the preset canned Tunes will work for you.
