07 charger Nitrous
jr86211
07 charger Nitrous
Post by jr86211 »
I plan on installing a 80 shot nitrous system on my 07 charger. I am currently using the 93 perf tune and I know the timing is advanced, but if I run a higher octane gas with the nitrous will that take care of the detonation problem or should I just install the factory tune when using nitrous.
RE: 07 charger Nitrous
No, just use the Predator to pull a couple degrees of timing in both timing paramaters.
SublimeTime
Re: RE: 07 charger Nitrous
Post by SublimeTime »
mikel wrote:No, just use the Predator to pull a couple degrees of timing in both timing paramaters.
Mike,
I will be running 75,100 & 125 shot on my "07 Daytona. I am running the 93 CAI tune. What kind of timing do I need to pull for each shot? I went one heat range colder on the plugs. Thanks.
Gary N
RE: Re: RE: 07 charger Nitrous
Your N20 manufacturer should have info on how much to pull...
