boost readings
armystrong
boost readings
does anyone know what kinda boost readings and mpg that the r20 will be giving on the 60hp tune
armystrong
armystrong
Truthfully all tunes are going to be a improvement over stock. Its all on how you drive your truck based on a couple conditions. Gear/Tire size and if you drive your vehicle normal not going WOT as much. Staying between 60-70mph on the highway you will see improvement. If you have a 4.10 gear ratio your speed will be different than a 3.73 but if your in overdrive and around 1800 rpms cruising on the highway this will be best for fuel economy. I can not paste ford documentation in our form but this is how they do their test.
Cole Stevens
