Why can't I see turn off MDS for my i2010
Jsolletti
Post by Jsolletti »
Just updated on pc and loaded 91 octane tune, but there is no option to turn off MDS?
Please help
Re: Why can't I see turn off MDS for my i2010
its gotta be there, under the modify parameters menu.
benpgreen
Post by benpgreen »
I have the same issue, I only see the options for MDS and coolant fan settings under modify stock tune, I don't have those options with any of the pre-set tunes. I would like to both disable the mds and adjust coolant fan settings for a 180 thermostat on the 93 tune.
please tell me what vehicles these are and post the info.xml file from the i2 drive.
Evilrt
Post by Evilrt »
Same here. I just bought it Saturday, got it today, updated on my Mac and no mds off, no fans, no throttle adjustment. I have a 2009 Dodge Charger 5.7
benpgreen
Post by benpgreen »
I have an 06 300c 5.7l.
Evilrt
Post by Evilrt »
is anyone at Diablo looking into this?
benpgreen
Post by benpgreen »
I had the same question. I just got mine earlier this week and purchased an extra license for my Jeep Commander, the tuning on my 300c does not seem to be complete and it tells me that the vehicle is not supported when I try it on my Commander. I have done two updates and it still will not connect with the commander or give me all of the options on my 300c. Under the modify parameters the only options I have are: Tire Size, Traction Control, and Transmission I attached a screen shot of my menu.
Evilrt
Post by Evilrt »
Yep, you beat me to it. I was going to post the same pcture.
this is the quick adjust menu, MDS is in the modify tune menu, go to advanced tune, select the tune you want, then choose modify parameters.
Evilrt
Post by Evilrt »
Followed the steps. Same result. Now what?
RoamPT
Post by RoamPT »
Im encountering the same issues. 2015 Dodge Charger R/T here i select my tune and i go to modify parameters and i can't adjust anything. Only those in that picture above are shown.
stackedactor
Post by stackedactor »
Same problem here for me on my 2014 Ram 2500. You can't turn off MDS in anything but "Modify Stock Tune"
Tconnor2
Post by Tconnor2 »
So, I have the same issue. Here is my question. Can you load the 93 octane tune and then go in and modify parameter and the 93 octane tune remain , but with the new parameters? Or can you load a modified tune with the adjustable parameters changed and then load the 93 octane tune and it keep the parameters?
Bobbyjo
Post by Bobbyjo »
I just got my I tune i2 for my 2016 ram R/T it only let me do tire size and traction control and the speed limiter.i can't adjust any thing else.i have been thru the whole tuner and it don't have any other perameter to adjust
