inTune regristration/update issues
Gardnen3
Post by Gardnen3 »
I purchased the i-1000 in like Jan of 2014 and registered it once i received it. Did the updates and attached it to my truck. I never updated it after that. I just recently released it from that truck and purchased a new one (2015 Silverado). When I plug it into the MAC to download/drag and drop the new updates to the inTune after it restarts it has the message cannot be updated until it is registered. Any help would be greatly appreciated. Thank you for your time and help with this.
garrett
Site Admin
Re: inTune regristration/update issues
Post by garrett »
please post the info.xml file from the intune drive, and we'll create the registration file for you. Thanks.
gto3764
Post by gto3764 »
I have the same issue......
gto3764
Post by gto3764 »
So........ :blowup:
gto3764 wrote:So........ :blowup:
the answer Garret provided above still applies here :)
Please post the info file.
gto3764
Post by gto3764 »
See attached.
info.xml
As requested.
(2.54 KiB) Downloaded 995 times
gto3764 wrote:See attached.
emai sent.
gto3764
Post by gto3764 »
Thanks Mike. Worked!!
cdedmundson
Post by cdedmundson »
Same issue. See attached.
info.xml
(1.97 KiB) Downloaded 975 times
Neight
Post by Neight »
Same problems, Thanks!
info.xml
(2.48 KiB) Downloaded 949 times
Dragonsys
Post by Dragonsys »
I started having the same issue after updating from 1r03w to 1r04b. I still have 8 more updates before the device is current.
info.xml
(1.07 KiB) Downloaded 885 times
craig.stainbrook
Post by craig.stainbrook »
I'm a new user and experiencing the same thing on my Mac. Every time I try to run the update the app crashes and I have to unplug the USB and reconnect it. Can you send me a registration file?
you can all use this one.
_registration.itf
(387 Bytes) Downloaded 989 times
Cescrader
Post by Cescrader »
I've got a intune 2 for my jeep srt8, I run a Mac and I received a custom tune today via email drag and drop it in to my tune file but nothing comes up on my intune 2 so can't load the tune up to the Jeep
dont put it in a folder, just in the root of the i2 drive.
Then eject it from the mac, let it reboot and copy it in again and it should import from there.
or, do it on a PC and it will import on the first try ;)
