Page 1 of 2
CUSTOM TUNE REQUESTED
Posted: Mon Mar 14, 2016 6:31 pm
by CJs197
I'd like to request a Custom 91 octane performance tune.
I have a 2005 Ford Mustang GT manual trans.
Details of my tuner device are in my signature.
The specific item I would like to have customized is my Dashpot setting. Reason is because my idle takes too long to drop between shifts.
I've already checked for vacuum leaks and cleaned the throttle body with no change to the slow rpm drop. It takes about 4-5 seconds for idle to drop from 3500 rpm to idle.
I recorded the slow dropping RPM's, click the image below to see it.
Re: CUSTOM TUNE REQUESTED
Posted: Tue Mar 15, 2016 11:36 am
no CAI on the car?
post the current last tune written file please.
Posted: Tue Mar 15, 2016 3:08 pm
by CJs197
No cai installed, do I have to upload the actual tune I'm using or can I tell you which one I'm using?
If I can just say which one it is, it's the 91 octane Performance Tune for a Manual trans 05 GT. My predator model and version are listed in my signature.
Posted: Wed Mar 16, 2016 4:12 am
by CJs197
no Cold Air Intake.
Posted: Wed Mar 16, 2016 9:51 am
CJs197 wrote:no Cold Air Intake.
give this a shot
Posted: Wed Mar 16, 2016 1:09 pm
by CJs197
Thanks Mikel! I'll try it out tonite.
Could you tell me what setting the dashpot was set to and what it is set to now?
Posted: Thu Mar 17, 2016 2:32 am
by CJs197
Well at a stand still, the RPMs come down quicker than before the custom tune but at speed, they come down slowly at the same rate as before and seem to drop as the vehicle speed drops. Any ideas why that would occur?
Posted: Thu Mar 17, 2016 3:30 am
by CJs197
Is there a setting called "drift" that is adjustable? I read on Mustang forum that a member who had the exact same issue that I'm having, went to a Ford Tech and they a vaguely recall the Tech altered something called drift which cured the issue.
Posted: Thu Mar 17, 2016 3:13 pm
by DiabloMatt
here you go. try that. let me know if this is good or if you need more aggressive or less.
Posted: Thu Mar 17, 2016 3:28 pm
by CJs197
DiabloMatt wrote:here you go. try that. let me know if this is good or if you need more aggressive or less.
Thanks Matt, I just confirmed that ill be picking up a JLT series 3 110mm CAI tonite, could you apply the Dashpot settings and settings for the JLT CAI into one tune?
Posted: Thu Mar 17, 2016 3:53 pm
by DiabloMatt
here you go...
Posted: Thu Mar 17, 2016 4:18 pm
by CJs197
You guys are AWESOME!
Posted: Fri Mar 18, 2016 4:48 am
by CJs197
DiabloMatt wrote:here you go...
Installed the JLT series 3 cai and tune, it's awesome but I need the idle to drop faster still. It's alittle better but it's still slow to drop.
Posted: Fri Mar 18, 2016 10:20 am
Can you record a quick log with the default pids so Matt can check it out?
Posted: Fri Mar 18, 2016 10:24 am
by DiabloMatt
CJs197 wrote:DiabloMatt wrote:here you go...
