received tool back from diablosport, need tech support
Posted: Mon Mar 21, 2016 5:11 pm
by josh6980
I also emailed via the site but not sure if it went through.
I was instructed to mail the tool in, and just got it back with a note saying "normal GM freeze issue" and to email tech support. We did a registry reset when I last called. Tool freezes right after determining vehicle info. It goes to a spinning wheel then freezes. Also, touchscreen barely works, only to very hard contact. Tried to pull tunes or logs off to attach but both folders are empty. Info.xml file attached. On a side note, my other intune tool that I have on my 2007 gmc yukon works on this truck as it is able to read/clear the CEL.
info.xml
(1.85 KiB) Downloaded 146 times
Re: received tool back from diablosport, need tech support
Posted: Mon Mar 21, 2016 5:54 pm
are you saying it is still freezing up after getting it back?
Posted: Mon Mar 21, 2016 5:59 pm
by josh6980
Yes
Posted: Thu Mar 24, 2016 3:13 pm
josh6980 wrote:Yes
save this to the root of the intune drive, and let the device import it, then let me know if it works properly in the truck.
