05 ford mustang gt emissions testing
Posted: Tue Mar 22, 2016 9:48 pm
by chester_tm
purchased 05 mustang gt with added steeda cold air intake, high flow cats with x pipe, and 91 octane tune through predator st7149 updated to vr 8r26 through post found on this forum, cant find any newer updates on the diablo website. vehicle has had no problem passing emissions in the 7 years ive been driving it. went to get my emissions test for renewal due this month, was told my vehicle was ineligible due to fact catalyst monitor is turned off. when restoring stock tune i receive lean faults both banks and o2 sensor stuck lean on bank 2. why does the tune turn off my catalyst monitor?? is there a more updated tune that will leave the cat monitor on? and if so will the monitor pass???
Re: 05 ford mustang gt emissions testing
Posted: Wed Mar 23, 2016 9:24 am
by DiabloMatt
chester_tm wrote:purchased 05 mustang gt with added steeda cold air intake, high flow cats with x pipe, and 91 octane tune through predator st7149 updated to vr 8r26 through post found on this forum, cant find any newer updates on the diablo website. vehicle has had no problem passing emissions in the 7 years ive been driving it. went to get my emissions test for renewal due this month, was told my vehicle was ineligible due to fact catalyst monitor is turned off. when restoring stock tune i receive lean faults both banks and o2 sensor stuck lean on bank 2. why does the tune turn off my catalyst monitor?? is there a more updated tune that will leave the cat monitor on? and if so will the monitor pass???
we turn them off as a high performace tune can cause the cat monitors to add fuel when you dont want it. flash the tune back in it (i assume the steeda 91 octane tune) and then read the last tune written out of the tool and post it up here. i will turn them back on for you so you can pass emmisions
Posted: Thu Mar 24, 2016 3:34 pm
by chester_tm
i am hoping this is what you needed, i re flashed the 91 octane steeda 90mm to the vehicle and then hit the export tune from tool button on the diablo sport downloader and this is the file it saved.... im hoping this is the tune and not the stock backup
Posted: Tue Mar 29, 2016 4:47 pm
by DiabloMatt
chester_tm wrote:i am hoping this is what you needed, i re flashed the 91 octane steeda 90mm to the vehicle and then hit the export tune from tool button on the diablo sport downloader and this is the file it saved.... im hoping this is the tune and not the stock backup
unfortunitly this is the original backup. you will have to export the last tune written as well
Posted: Wed Mar 30, 2016 10:08 pm
by chester_tm
OK SO I WENT INTO OPTIONS AND EXPORTED CUSTOM TUNE.... IF THIS ISNT THE RIGHT FILE ILL HAVE TO CALL AND FIGURE OUT WHAT IM DOING WRONG.... PLEASE GET BACK TO ME ASAP SO HOPEFULLY I CAN GET THIS WORKED OUT BEFORE THE WEEKEND
THANKS
Posted: Fri Apr 01, 2016 11:28 am
by chester_tm
GOODMORNING. DO YOU HAVE AN UPDATE FOR ME? IS THIS THE CORRECT FILE?
Posted: Fri Apr 01, 2016 3:24 pm
hes been a little backed up on tune development, shouldnt be too much longer.
Posted: Fri Apr 01, 2016 4:13 pm
by chester_tm
THANK YOU
