I recently picked up an Intune from a forum for my Caliber and was psyched to plug it in and do a little bit of tuning to my car, but every time I tried to load the regular Diablotune (I did not try to modify the tune, just went with the base Diablotune) it says that it fails, and I need to recover the stock tune. Then as I'm trying to revert back to the stock tune, it says that it failed to load the stock tune, and needs to recover. So it's stuck in this weird recovery mode limbo. I called tech support and they reset the device for me, but if I try to write a tune it does the same thing. However the last time I called, I loaded the Diablotune, and instead of trying to go into recovery mode to go back to the stock tune like the device wanted me to, I simply unplugged the Intune and I have the Diablotune loaded on my ecu even though it said that it failed. The only drawback is that I can't do anything else with the Intune until an update comes out because when I plug it in, it wants to do the recovery mode thing again.
So basically I started this thread to see if a moderator can update me when they get an update out to fix this problem. And hopefully I helped someone who may have the same thing going on.
Waiting on new tune for Caliber Srt4
DViper0020
Re: Waiting on new tune for Caliber Srt4
Bump. Any information?
We're still looking into this, there is something about the key cycles that we are not seeing.
DViper0020
Thanks for the response! Looking forward to a resolution.
DViper0020
Bump. Still waiting on an update.
