Froze Up & In Trouble.
SalyersSierra2012
Post by SalyersSierra2012 »
Fellow InTuners,
Upon pulling into driveway last night I noticed my truck what seemed to be choking out then check engine light came on. My first thought was that my Intune will extract any code then I can proceed from there. Well I hooked Intune up and it stated as always. "turn ignition on, but do NOT start vehicle" to determine vehicle information. I did and it started its circle moving cursor for about 5 seconds and then froze. Well 20 minutes later and is still froze. I need to take truck to dealership as I have an extended warranty that may cover this issue but I do not want them to see that I have this beast tuned up to Diablo....Any suggestions as to how to un freeze Intune and get it to working again ?
Thanks In Advance.
Re: Froze Up & In Trouble.
this is a bug we can get around, can you post the files from the tunes folder here please?
SalyersSierra2012
mikel wrote:this is a bug we can get around, can you post the files from the tunes folder here please?
Thanks for the quick reply. I have been trying to post files as you requested but I am not having any success. When I plug my tuner into my computer I want to go to the tunes files and when I try to open he only two files that I have are a Backup.grg files and I am unable to open either one of them up.
Am I not doing something correctly ?
Thanks for your help mikel.
SalyersSierra2012
I was able to extract this from an info file..... but if you can understand this my hats are off to you.. :shock:
<?xml version="1.0"?>
-<tool_info>
<main svn="8521" sw_rev="1r04i" full_version="InTune-1r04i 08/03/2015 01:32:36 PM"/>
<registration status="0" sn="JNUD991-6"/>
<cal_id CM2="20791915, 22803644, 20808548" CM1="24261871, 24263533, 24257957, 24257970" PCM="12653249, 12640885, 12640857, 12625892, 12620683, 12640909, 12640941, 12640916"/>
<restore bc="20" vin="1GTR2VE74CZ254461" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01e" mfr="DCX"/>
<db pid="1r01b" tune="1r02a" mfr="FORD"/>
<db pid="1r01a" tune="1r02o" mfr="GM"/>
-<license tuned="1" avail="1">
<tuned vin="1GTR2VE74CZ254461"/>
</license>
<updates count="3"/>
<oem tool_oem="DIABLO"/>
<reg reg="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"/>
</tool_info>
