a PING sound from the motor ???
ncyz1v
Post by ncyz1v »
I keep hereing a ping in the motor ????
I did not due the upgrade because the shift on the fly still works.
I hate to loos it but if that is what i have to do then so be it!
just let me know????
kate and 06 dodge.jpg (24.92 KiB) Viewed 2352 times
Nick,
Smart Line products
06 Dodge 6 speed,4x4 dually on 265/70/19.5's
predator POWER!!!
95' dodge diesel with 165k that sounds better than my 06?
johan
RE: a PING sound from the motor ???
Post by johan »
Hmm, we have not had any such complaints and the newer revisions do not have any timing altered so it would most likely behave the same way as your current rev. Have you checked the obvious fuel filter?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
ncyz1v
Post by ncyz1v »
fuel filter??? NO but i will replace it today! and let you know.
Thank's.
Nick,
Smart Line products
predator POWER!!!
johan
Post by johan »
Yeah i change mine with every oil change.
Diablosport INC
Dodgezilla
Post by Dodgezilla »
A little ping is normal when it gets this cold out Nick. Is the ping really bad or is it just a hint that you noticed? My truck is 100% stock right now and I still hear some ping on occasion.
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
ncyz1v
Post by ncyz1v »
all i have is the exhaust and the chip set in -3...
stack perf.
I changed the oil and fuel filter no change!
I was thinking maybe the stack tune with nothing else might be the problem?
"BUT" i can not put in on perform with out installing the 1500 dollar clutch i got 4 months ago...might as well put on the Jake break i got also. but I just do not have the time....AND every one says i will hate the new clutch????
Nick,
Smart Line products
predator POWER!!!
ncyz1v
Post by ncyz1v »
P.S. the 95 Dodge i got a few months ago with 165K miles on it sounds better than my 06 with 40k on it.how can that be????
It pers like a dream. this thing sounds like the timeing is off the valves are loose and the cam chain is smacking the cover...
the valves have been checked...could it all be the predator?????
Nick,
Smart Line products
predator POWER!!!
johan
Post by johan »
If this sound was not present when you first installed the tuner and started building progressively then you might have injector issues, quite common on the 06-07 cummins.
Diablosport INC
ncyz1v
Post by ncyz1v »
johan wrote:If this sound was not present when you first installed the tuner and started building progressively then you might have injector issues, quite common on the 06-07 cummins.
I will have it checked.
Nick,
Smart Line products
predator POWER!!!
