a PING sound from the motor ???
Posted: Wed Feb 13, 2008 8:23 pm
by ncyz1v
I keep hereing a ping in the motor ????
I did not due the upgrade because the shift on the fly still works.
I hate to loos it but if that is what i have to do then so be it!
just let me know????
RE: a PING sound from the motor ???
Posted: Thu Feb 14, 2008 9:21 am
by johan
Hmm, we have not had any such complaints and the newer revisions do not have any timing altered so it would most likely behave the same way as your current rev. Have you checked the obvious fuel filter?
Posted: Thu Feb 14, 2008 11:56 am
by ncyz1v
fuel filter??? NO but i will replace it today! and let you know.
Thank's.
Posted: Thu Feb 14, 2008 11:59 am
by johan
Yeah i change mine with every oil change.
Posted: Thu Feb 14, 2008 1:46 pm
by Dodgezilla
A little ping is normal when it gets this cold out Nick. Is the ping really bad or is it just a hint that you noticed? My truck is 100% stock right now and I still hear some ping on occasion.
Posted: Sat Feb 16, 2008 9:05 am
by ncyz1v
all i have is the exhaust and the chip set in -3...
stack perf.
I changed the oil and fuel filter no change!
I was thinking maybe the stack tune with nothing else might be the problem?
"BUT" i can not put in on perform with out installing the 1500 dollar clutch i got 4 months ago...might as well put on the Jake break i got also. but I just do not have the time....AND every one says i will hate the new clutch????
Posted: Sat Feb 16, 2008 9:10 am
by ncyz1v
P.S. the 95 Dodge i got a few months ago with 165K miles on it sounds better than my 06 with 40k on it.how can that be????
It pers like a dream. this thing sounds like the timeing is off the valves are loose and the cam chain is smacking the cover...
the valves have been checked...could it all be the predator?????
Posted: Sat Feb 16, 2008 7:23 pm
by johan
If this sound was not present when you first installed the tuner and started building progressively then you might have injector issues, quite common on the 06-07 cummins.
Posted: Sat Feb 16, 2008 11:54 pm
by ncyz1v
johan wrote:If this sound was not present when you first installed the tuner and started building progressively then you might have injector issues, quite common on the 06-07 cummins.
I will have it checked.
