93 tune rich run 3-4k
Posted: Sun Jun 26, 2016 9:10 am
by Emtj_
Is it comon for the 93 tune to run the car a bit rich (10.4) ?
Ive searched all over and it seems the tune runs cars lean.
After 4k itll go up to about 11.1 .
Im just curious because my searches all come up that the tune runs your car lean.
My mods are
3tip and map
3in mpx exhaust
Bfic
No boost leaks
Aem wb
Ive leaned it out about 4% from 3-4k Im datalogging and see no knock either. Just curious.
Thank you
Re: 93 tune rich run 3-4k
Posted: Mon Jun 27, 2016 9:35 am
well, you are using a custom tune, not the canned tunes, correct?
Thats something the tuner should address for you.
Posted: Mon Jun 27, 2016 8:28 pm
by Emtj_
whered you get "custom tune" from?.. I didnt mention anything about a tuner. Its the canned 93 tune
Posted: Tue Jun 28, 2016 11:04 am
well, thats your problem, the 3 bar MAP/TIP require a customtune, you cant run them on the stock tune or the provided performance tunes.
Posted: Wed Jun 29, 2016 3:58 pm
by Emtj_
mikel wrote:well, thats your problem, the 3 bar MAP/TIP require a customtune, you cant run them on the stock tune or the provided performance tunes.
Im assuming you are talking about the rescale. Which i got the rescale done. Along with the cot shut off
So ur saying the rescaled tune im running is not the 93 tune?
Just a bit confused
Posted: Thu Jun 30, 2016 3:12 pm
yes, a custom tune is not the canned 93 tune.
The rescales are meant to get the car running safely, you need to custom tune it to dial it in.
