2010 Ram 1500 and InTune I1000 vers.1r04j
Hello today I update my intune I1000 for use a new car....2010 RAM 1500 but this need the update!!
Re: 2010 Ram 1500 and InTune I1000 vers.1r04j
click the green check then connect it to a pc and let the updater program run and it will download the file needed.
after click green....
- IMG_9163.JPG (102.35 KiB) Viewed 4108 times
right but do not have a new update!!
- IMG_9167.JPG (125.22 KiB) Viewed 4047 times
Firmware info......
- IMG_9165.JPG (107.81 KiB) Viewed 4047 times
post the info.xml file from the intune drive please.
Thank you Mikel
- info.xml
- (2.77 KiB) Downloaded 264 times
its not asking for a cal update here, please try it again in the truck and when it says it needs an update click the green check then post the new info file.
this is a file info for update request
- info.xml
- (2.86 KiB) Downloaded 185 times
please run the updater then it will download the file you need.
