U7135 can't connect to win7 with USB serial cable
Posted: Sun Aug 07, 2016 1:49 pm
by unpredictable1
I have the baud rate set on both ends to 115200, I used the driver from the downloads section, and the DSDownloader cycles back and forth between COM1 and COM3 looking for the tool. (It's on COM3)
It's a gigaware usb-serial cable, I have no errors in device manager either.
I used PL2303_Prolific_GPS_AllInOne_1013.exe for the driver.
I need to update the CALID on the Predator because in my 2005 300C, I get the "this vehicle needs an update" message.
Thanks!
Re: U7135 can't connect to win7 with USB serial cable
Posted: Mon Aug 08, 2016 9:13 am
what does the device manager show for that device?
Posted: Mon Aug 08, 2016 2:05 pm
by unpredictable1
Here is a screen cap, I'm going to try another cable
Posted: Mon Aug 08, 2016 2:25 pm
by unpredictable1
Another cable I have looks like this in the attached. Does the 7135 device itself have to be on a certain screen or anything?
Posted: Mon Aug 08, 2016 4:57 pm
you need to double click on them to see what the status is.
Posted: Mon Aug 08, 2016 6:22 pm
by unpredictable1
I will once I get home from work - never had much time at lunch today.
If memory serves me correct, when I went into properties it said it was functioning correctly. By the time I'm home you folks will probably be gone for the day, I'll update this thread though.
Cheers
Posted: Mon Aug 08, 2016 7:00 pm
by unpredictable1
Here it is with the second cable I tried, the first one says the same thing.
Posted: Mon Aug 08, 2016 9:17 pm
by unpredictable1
So one thing I didn't do is try the second cable I got a loan of, back onto my original Windows 10 machine. Did that, DS Downloader saw it right away and I was able to calibrate the tool and tune my car.
Thanks.
Posted: Tue Aug 09, 2016 10:23 am
odd, must have been some bad cables.
