PCM Update issue...
PCM Update issue...
Cannot connect. Saying PCM recalibration needed.
Need to get an update from DS(Mac user)
- info.xml
- (1.92 KiB) Downloaded 983 times
Re: PCM Update issue...
save this to the i2 drive and let the tool import it then try to tune it again please.Pmexpert wrote:Cannot connect. Saying PCM recalibration needed.
- group_update.itfg
- (17.55 MiB) Downloaded 1069 times
mikel wrote:save this to the i2 drive and let the tool import it then try to tune it again please.Pmexpert wrote:Cannot connect. Saying PCM recalibration needed.
Dear Mike, I have an inTune DCX not i2....
Hi Mike, any updates so far? too many modes that are sensitive to programmer... need it asap
Mike, i've started to reach Vas by mail since September 4th. And trying to get an updates here on forum since 6th.
Guys, I cannot get a files needed for almost two weeks...
That's not funny anymore. I've been using your products for 6 years, Predator, Trinity, now inTune DCX. But what happened to support, guys? I cannot use programmer and I can't get a support for weeks.
the file I posted will work to update the tool, please load it and let me know.
Thanks for the info. Installed an update, connected to the Vehicle - the same issue...
New info file is attached
PS Please try to reply asap, as it takes too long
- IMG_2128.JPG (2.23 MiB) Viewed 21887 times
- info.xml
- (1.92 KiB) Downloaded 913 times
Hey Mikel, any updates so far?
please run the updater again now and it will download the file you need.
Mikel, nothing works as I have a MacBookmikel wrote:please run the updater again now and it will download the file you need.
I reinstalled "group update" file, but again: "PCM Recalibration is needed"! It says it will update next time I connect to PC, but I don't have any PC!!! It is a particular topic for those with Macbooks not PCs!
post the new info file please and I will make the update for you
