InTune I1000 Registration Issue
Posted: Fri Sep 16, 2016 2:07 pm
Hi there,
I recently picked up a used InTune. The prior owner reset his vehicle and it appears to be unmarried. When I first plugged it in to update, it appeared to install the updates just fine. However, my vehicle is claiming it needs a PCM Calibration update and when I plugged back into the computer, the unit told me it needed to be registered to update.
It should already be registered to the prior owner, correct? I am attaching the info file if that helps at all.
Thanks in advance for the help!
