well i was given a Predator programmer i believe its U7146 locked up previous owner crashed car & didnt get stock settings bak in so my
QUESTION is:
1) can i get it unlocked ??????
2) & if so can i get it programmed to a different vehicle not a mustang
my vehicle is a 99' f150 5.4 is it possible
3) ifso where can i sent it out to or where can i take it to get reprogrammed???
4) approx. cost for reprogram $$$$
if it can be unlocked but not reprogrammed for my vehicle
I'll put it up for grams for anybody who can put it to good use!!!
THANKS!! ANYBODY LET IT BE THE WISEMAN to answer the doubt
U7146 LOCKED UP
Sorry to say but I guess SOL comes to mind. AFAIK they cannot be unlocked. EVen worse is there's no way to get it to work on the F150, you need a predator specifically for that truck. You might need to look at the "U7158: 1999-2004 Ford Factory Supercharged Trucks" That's all I found for F150. You definitly need a different tuner though. The tuner you have is only for the 98 thru 04 Mustangs.
Your 99 F150 would require a U7153. The U7146 cannot be reprogrammed. Also, the only way we can/will unlock it is with proof from the original owner that the car was totaled (insurance company papers, for example). They would need to be faxed into us at 561-908-0048 and you would need to call in shortly after.
Christy High
lurker.
lurker.
