update issues on mac..again
ffwatson21
when i plug in to mac and run the update, it always quits unexpected.
i finally got the i2 to update, but now everytime i plug it in to computer, it installs updates on the i2 before i open the i2 driver then says press continue to reboot. when i press continue, it says please wait. ive tried it numerous times for sometimes hours and it never reboots.
This thing is becoming quite the pain
ffwatson21
Re: update issues on mac..again
update...somehow it finally rebooted and i set up wifi. now when i plug it in to mac it says no updates available but the date still says september 2015. is that normal?
All good.
MakeItAMudLight
I'm having this same issue with my i2. It's stuck on please wait and nothing I do changes that. What should I try next?
slimchance
ditto !!!
having same problem!
been two days screwing with this!
i even downloaded windows on my mac but can't open the usb for update.
i switched back to the mack and it says no more updates, complete ....please wait
What's the current update number wise on the i2030? Just making sure I'm updated before I run the tune. Thanks
i2010, I'm having the exact same issue. Been going on for 2 days now, appears that all the updates finally completed but I'm stuck on "Please Wait". I left it hooked up this morning going on 2 hours now and still displays "Please Wait" after the re-boot prompt. What is going on here? Wish I never updated, everything worked great before this.
does it boot properly in the vehicle?
can you post the info.xml file from the i2 drive?
I see macs put files on the i2 drive that do not belong there all the time, might check that as well.
Outdoorsman87
I'm having the same issue, I just received my tuner and plugged it in to the computer before hooking it up to my truck. First i had to update my Java which I did no problem. Then when i opened the updater it would quit unexpectedly right at the end of the update, then the programmer would just start updating automatically at reboot it just get stuck at please wait. So i connected to wifi ran the update and it rebooted fine. Tried programming my truck at this point and got a message that my vehicle is not supported may need to update please connect to PC. WTF i had a super chips flash paq before this and had zero issues ZERO. Made the switch to diablo because all the ram truck guys swear by them. This is the most frustrating thing. I payed over $400 for something that isn't working.
run the wifi updater again and it should download the update for the vehicle, if not post the info.xml file from the i2 drive here please.
i2010, I'm having the exact same issue. I'm stuck on "Please Wait".What is going on?
unplug it and it should be fine.Majvall wrote:i2010, I'm having the exact same issue. I'm stuck on "Please Wait".What is going on?everything worked great before this.
No, its not! Please wait....... Every time!
can you access the i2 drive/Majvall wrote:No, its not! Please wait....... Every time!
please post the info.xml file from the drive here.
Please wait. Group update 5
