I found this on another website. Is there a link or somewhere we can find info for every PID available ??...........for us dummies that are trying to learn ?
Map-->
AV MAP TO USE--Absolute pressure inside your intake manifold(Boost = MAP - BARO)
AV TIP TO USE--use min TIP psi as "Baro"
FUEL FLOWS--->
1/1 LONG TERM ADAP--How much your PCM is adjusting the fuel table--Usually under 15% is fine, Over 20% is borderline, more than 25% is not fine
1/1 SHORT TEM ADAP--Show instantaneous Upstream O2 sensor adjustment to fuel table
BARO-- Barometric pressure--Needed for boost calc(Boost = MAP - BARO)
PRATIO ---MAP/BARO
TOTAL VE BANK1
COOLANT TEMP-->
ECT--Engine Coolant Temperature
CHARGE TEMP-->
ACT--Air Charge Temperature--Measured by ACT sensor in cold pipe right before throttle body
DESIRED FUEL AIR-->
OPEN LOOP FA--Commanded A/F that the PCM is trying to reach. 93tune=11.77:1. THIS IS NOT YOUR TRUE A/F!! You need a wideband to measure your actual A/F. OLFA is usually anywhere from .2 to 3 points or more different from TRUE A/F.
Torque Management-->
TRQ DESIRED--Final Desired Torque the PCM is trying to reach after ALL modifiers applied
Wastegate Control-->
TURBO WG DC--Final WG solenoid duty cycle
Trinity PIDs
General Trinity Support
Jump to
- Welcome to DiabloSport
- ↳ Announcements
- ↳ Test Vehicles Wanted
- i2/i3 Technical discussion
- ↳ i2/i3 for Dodge, Chrysler, Jeep and Ram
- ↳ i2/i3 for Ford vehicles
- ↳ i2/i3 for GM vehicles
- ↳ Ignition updater
- Trinity 2
- ↳ T2 for Dodge/Chrysler/Jeep/Ram
- ↳ T2 for Ford
- ↳ T2 for GM
- ↳ Trinity MX monitor
- PredatorX
- ↳ PredatorX for GM vehicles
- ↳ PredatorX for Dodge/Ram vehicles
- ↳ PredatorX for Ford vehicles
- ↳ PredatorX Requests and Feedback
- Predator 2 Support
- ↳ Predator 2 for Chrysler/Dodge/Jeep/Ram
- ↳ Predator 2 for GM
- ↳ Predator 2 for Ford
- Pulsar
- ↳ Pulsar for Ram
- Trinity Technical Discussion
- ↳ General Trinity
- ↳ Trinity Ford Gas
- ↳ Trinity Ford Diesel
- ↳ Trinity Dodge Gas
- ↳ Trinity Dodge Diesel
- ↳ Trinity GM Gas
- ↳ Trinity GM Diesel
- inTune i-1000 Technical Discussion
- ↳ General inTune forum
- ↳ Auto Updater/PC related issues
- ↳ Mac/Non Windows based issues
- ↳ inTune DCX (i-1000-DCX)
- (Legacy) Predator Technical Discussion
- ↳ Predator Ford Gas
- ↳ Predator Ford Diesel
- ↳ Predator Dodge Gas
- ↳ Predator Dodge Diesel
- ↳ Predator GM Gas
- ↳ Predator GM Diesel
- General Technical Support
- ↳ DataViewer/DV2
- ↳ General Support
- ↳ Custom Tune Support
- ↳ DeltaChip
- ↳ MAF.i.a
- ↳ DSDL
- ↳ PowerPuck/Extreme PowerPuck
- ↳ CatchCan Support
- DiabloSport Community
- ↳ General Questions
- ↳ Lounge
- ↳ Suggestion Box
- ↳ Future Product Requests
