Got the i2 updater working finally after a tip somewhere else to delete the native group_updater file - thanks.
Now when the latest update downloads using the updater I get:
"Error moving file group_update.itfg to device: No space left on device".
The device info from OS says there is 104.6 MB total capacity, 8.2 MB available, 96.5 MB on disk used.
Any advice?
Error moving file...no space left on device
Re: Error moving file...no space left on device
Progress report...no progress to report:
Tried on a Win10 machine.
Update downloads and begins to copy but then fails.
"IO operation will not work. Most likely the file will become too long or the handle was not opened to support synchronous IO operations"
The i2 then briefly disconnects from the PC and reconnects.
is there anything in the intune drive that doesn't belong there?
Not to the best of my knowledge. I've only opened it and deleted the two files.
group_update_reboot.itfg
group_update.itfg
Leaves:
info.xml
<dir> logs
<dir> runtime
<dir> tunes
<dir> Updater
Interestingly when I try and copy the two files I deleted back onto the drive it says it's out of space....they were there, but now there's no room for them. Space info hasn't changed. 8 MB available, 104.6 MB total capacity. Obviously if that's the case the 48 MB update files aren't going to fit.
group_update.itfg
Leaves:
info.xml
<dir> logs
<dir> runtime
<dir> tunes
<dir> Updater
try using the show hidden file option, gotta be something there or on a folder.
Success
FFS I hate Mac. No way to see hidden files, so back to the Win10 machine, where they become visible, and lo, the files I deleted are somehow lingering in a hidden directory. POS.
Anyway, delete delete delete, re-run uploader and all seems fine.
Next, find a warm(ish) day to install the new PCM and then new tune and tire size.
Thanks for the help.
I had a feeing this was a Mac-ish issue
