2016 FORD F150 2.7l ECO NOT SUPPORTED
htg
Post by htg »
IM HAVING TROUBLE GETTING MY I2 TUNER TO CONNECT TO MY TRUCK CAN YOU HELP?
I HAVE ATTACHED MY INFO FILE.
Re: 2016 FORD F150 2.7l ECO NOT SUPPORTED
we'll get this added asap.
DiabloMatt
Post by DiabloMatt »
save this onto your computer and drag and drop it to your main i2 drive. let the tool import it and reboot. then you should be able to plug into your truck and tune it :) please let me know :D
htg
Post by htg »
didn't work still says vehicle is currently not supported. I'm attaching the info file from the latest try.
DiabloMatt
interesting.... uno memento
htg
Post by htg »
Anything yet?
sorry for the delay, Matt is still looking into this.
DiabloMatt
im trying to figure out why this isnt in there cause i added it thurs
DiabloMatt
my deepest apologies... i though you had a BNPR2 which i added support for. you ACTUALLY have BNPP2. i'm adding support as we speak.
htg wrote:Anything yet?
here is the update,
htg
Post by htg »
Works good but it didn't give me the option to turn off engine shutoff when stopped
htg wrote:Works good but it didn't give me the option to turn off engine shutoff when stopped
are you looking through the modify parameter menu in the advanced tune section?
htg
Post by htg »
No just set the 87 tune and turned off speed limit
htg
Post by htg »
Got an email that said to update so I did it was a group update when I took it back to my truck it wouldn't connect again saying vehicle not supported. Back to the first problem.
htg wrote:Got an email that said to update so I did it was a group update when I took it back to my truck it wouldn't connect again saying vehicle not supported. Back to the first problem.
who emailed you to update?
You need to reload the file we posted here then it will work fine.
