2017 GMC Sierra top speed limit with I2
tuffram1996
Post by tuffram1996 »
I have tried the advanced tune and the easy tune selected disable top speed limit on both and still cuts off at 98MPH any suggestions???
tuffram1996
Re: 2017 GMC Sierra top speed limit with I2
Anyone???? Mikel???? LEW??? Help???
I have no idea man... from what I've seen across the forum, people have not been able to get a tune successfully installed at this point.. even emails I've gotten from people personally.. they've thought the tune was installed ok, but it didn't actually change anything.. sooo.. nothing I can do or help with man, I have no idea.. gotta wait for Mikel/diablosport to get things fixed up...
tuffram1996
06MonteSS wrote:I have no idea man... from what I've seen across the forum, people have not been able to get a tune successfully installed at this point.. even emails I've gotten from people personally.. they've thought the tune was installed ok, but it didn't actually change anything.. sooo.. nothing I can do or help with man, I have no idea.. gotta wait for Mikel/diablosport to get things fixed up...
Thanks for your response LEW I have a feeling mine did not install even thought it says it did but I really cant tell any difference in the drivability and from what I understand even the caned tunes really wake these trucks up a lot. hope they get it figured out soon. as soon as they get things figured out and I get 150 + miles on it I will be purchasing one of your custom tunes LEW.
tuffram1996
Ok Mikel I will do it tonight but it will be after you close for the weekend so look for it Monday thanks.
19trax95
Post by 19trax95 »
Op, you seem to be having the same issue I am. It says it installs but the truck doesn't actually get changed in any way. I've tried everything I could think if. I was in contact with mikel and he sent a tune to try but that won't get recognized by the intune for whatever reason. So it definitely seems the 2017 trucks are still not really 100% working.
tuffram1996
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_G" status="0" sn="1QQGPUQAUW"/>
-<applications count="5">
<application rev="2t01te" name="vehicle"/>
<application rev="2r01e" name="updater"/>
<application rev="2t01lc" name="gui"/>
<application rev="2t01eb" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2t01gf" vin="2r01h" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM" tune="2t02zt"/>
</databases>
-<system rev="1r01b" config="1r01d">
<option name="Wifi" driver="v4.0.2_9000.20130911" enabled="true"/>
</system>
<last-connected vin="3GTU2NEC1HG269983" mfr="GM" calid="12677878, 12678700, 12678679, 12667480, 12667659, 12667714, 12667794, 12679741"/>
<last-connected calid="24283721, 24283176, 24283171, 24272181, 24274482, 24283178"/>
-<licenses tuned="1" available="1">
<license vin="3GTU2NEC1HG269983" mfr="GM" calid="12678679" ecu="ECM"/>
</licenses>
<reg reg="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"/>
</tool_info>
tuffram1996
Here is the back
tuffram1996
Last tune written
tuffram1996 wrote:Last tune written
please restore the stock tune, then update the device with ignition, then reload the tunes, they will work from there.
That was our fault.
tuffram1996
Ok will do Mikel is it showing the truck is tuned now or not??
tuffram1996
Ok did the update last night and it seams to be working correctly today thanks again for your help Mikel.
tuffram1996 wrote:Ok did the update last night and it seams to be working correctly today thanks again for your help Mikel.
glad to hear it.
