U7198
Posted: Sun Mar 16, 2008 8:29 pm
by stealthsierra
If I buy a U7198 for my trans am will I be able to log A/F % ? If not what would I follow for tuning ?
RE: U7198
Posted: Mon Mar 17, 2008 11:09 am
no, the 7198 does not have the AFR parameter...
it's not the predator's fault.. it's the GM PCM... it doesn't report that info...
the AFR parameter only recently appeared in the GM CAN-bus protocol ECM's..
RE: U7198
Posted: Mon Mar 17, 2008 3:39 pm
by sickREDsierra
it will surely just read the mV signal from the narrowband o2's.
Re: RE: U7198
Posted: Mon Mar 17, 2008 7:26 pm
by stealthsierra
I've already read the sticky
RE: Re: RE: U7198
Posted: Mon Mar 17, 2008 7:29 pm
by stealthsierra
So, what I'm wondering is the only way get a good A/F reading with a wideband in my case ?
RE: Re: RE: U7198
Posted: Mon Mar 17, 2008 10:19 pm
yes... you'd need to get a wideband hooked up...
RE: Re: RE: U7198
Posted: Tue Mar 18, 2008 10:38 am
In any case, the only way to get accurate A/F info is from a wideband....
RE: Re: RE: U7198
Posted: Tue Mar 18, 2008 6:32 pm
by sickREDsierra
and to obtain an accurate wide-band setup, you must break out the piggy bank. $$$$$$$$$
around $400 or so for everything....some are cheaper.
