i2050 vs i2030 ?
i2050 vs i2030 ?
What other differences are there between them besides that the i2050 wont accept Custom Tunes ? Can the i2050 change shift points, turn off TM, adjust for larger tires and gear ratio changes ?? also can the i2050 turn off 4 cyl. mode ?
Re: i2050 vs i2030 ?
the i2050 has less user adjustable parameters available on it, and it can not do custom tuning.
if you are in Cali, i2050 is the only way to go.
If not, i2030 is a better option.
