Intune won't connect- "Unable to resolve Tune for LTW" Error
BowtieGuy1809
Post by BowtieGuy1809 »
I currently have the 87 Octane Tune on my 2008 Silverado. I tried to go into the tune and adjust the torque management but the inTune won't load.
It connects fine and I click Adjustable Parameters and then it prompts to turn on the truck. When it tries to connect to the truck I get the "Unable to resolve Tune for LTW ().
I made sure that radio and AC where off and tried it 2-3 times with the same thing. The lights come on and I try to turn them off as quickly as possible but that doesn't work.
Any thoughts why it's doing this? I've never seen this error before.
Re: Intune won't connect- "Unable to resolve Tune for LTW" E
try selecting a tune then select modify parameters.
BowtieGuy1809
So do I need to go in and act like I'm installing the 87 Octane Tune and then adjust TM at that time?
yes.. you have to select the tune you want to install, then you choose to modify it, make your changes.. exit back out, and install/apply the tune to reinstall it with your changes.
BowtieGuy1809
Thanks! I was trying to just do the Adjustable Parameters based on the how-to posted on SilveradoSierra.com and didn't realize I had to go into the tune again.
Also, how can I tell if I have the latest version installed? What is the latest version for the 2008 Silverado?
