Hey,
I have 2004 GMC Sierra 8.1 w/allison. It runs well stock. I loaded the 87 tune and it now has almost no throttle response when taking off from a dead stop. Once it shifts to second and above 3,000 RPM's it seems to run ok. I loaded the original backup so I could drive the truck.
What can be done to fix this problem?
What info do you need from me?
Thanks.
2004 GMC Sierra 8.1 with no throttle response
Screaminxl
Screaminxl
Re: 2004 GMC Sierra 8.1 with no throttle response
Here is the original tune and 87 tune.
Used gm_j1850 1r13c
Used gm_j1850 1r13c
- PCM_587603587704_87_Octane_Tune.grg
- (6.25 KiB) Downloaded 374 times
- PCM_587603587704.grg
- (31.73 KiB) Downloaded 356 times
here you goScreaminxl wrote:Here is the original tune and 87 tune.
Used gm_j1850 1r13c
- PCM_587603587704_87_Octane_Tune_custom.grg
- (26.96 KiB) Downloaded 364 times
