Please help, new member with a question.
Posted: Sun Mar 23, 2008 7:03 pm
by Tanner
I bought a truck this past weekend that came w/ the diablo u7165. When I plug it in to do a tune it says "your vehicle is not in our database. contact your dealer for a free update. you cal_id is 'vxcf5h5' " what do i do??
The truck is a 2006 f250 powerstroke any suggestions?
RE: Please help, new member with a question.
Posted: Sun Mar 23, 2008 7:24 pm
by kmacicek
what revision number is it
Posted: Sun Mar 23, 2008 7:28 pm
by Tanner
It says v8r14. Is that what you are talking about? Thank you for replying!
Posted: Sun Mar 23, 2008 8:32 pm
by Tanner
anybody out there?
Posted: Sun Mar 23, 2008 10:42 pm
by BIGROC
Tanner,YOUR CAILID IS NOT SUPPORTED IN THE R14 REVISION.YOU NEED TO UPDATE THE TUNER WITH THE R20 REVISION AND IT SHOULD BE FINE. :D
Posted: Sun Mar 23, 2008 10:47 pm
by Tanner
Ok, I will try that as soon as I get the cable. The main thing that I dont understand is why this thing worked in the past for the previous owner. Can you explain why that is? Thanks for the reply! -Tanner
Posted: Sun Mar 23, 2008 11:06 pm
by BIGROC
Tanner,IF THE OWNER HAD IT AT FORD THEY COULD HAVE DONE A REFLASH ON THE PCM AND THE NEW CALID WOULD NOT BE SUPPORTED BY THE R14 REVISION.IF YOU CHECK UNDER THE HOOD,OR ON THE RAD. SUPPORT THEY WOULD HAVE TAGGED IT AT THE FORD DEALER IF THEY REFLASHED IT.
Got it working thanks! But not a noticable gain of power!!
Posted: Tue Mar 25, 2008 11:40 am
by Tanner
I dont see much difference than stock with this thing. What is the deal?
Re: Got it working thanks! But not a noticable gain of powe
Posted: Tue Mar 25, 2008 12:54 pm
Tanner wrote:I dont see much difference than stock with this thing. What is the deal?
So you were able to update it and load the tune?
You should certainly feel the tunes, even if its just the 40hp tow tune.
yes I got it to load
Posted: Tue Mar 25, 2008 3:18 pm
by Tanner
and I am on the 65hp tune. It just does not feel any different than before. I thought there was suppost to be a noticable difference. I will drive it a little more this evening and see what I find.
RE: yes I got it to load
Posted: Thu May 08, 2008 11:16 pm
by thomas5853
Do I have to upgrade anything in order to use the 100hp setting?
Posted: Fri May 09, 2008 9:22 am
Yes, we recommend a 4" turbo back exhaust and EGT guages...
Posted: Fri May 09, 2008 11:28 am
by thomas5853
So far, when I used the 100hp setting I got 20 mpg, but when I used the 65hp, I got 15 mpg in the city. My next step is to try the tow tune and see what mpg I get, plus see about the 4" turbo back exhaust. When I used the 65hp setting, the transmission didn't shift as smooth as when it was in the 100hp setting. Any ideas?
Re: RE: yes I got it to load
Posted: Fri May 09, 2008 12:39 pm
by cole
thomas5853 wrote:So far, when I used the 100hp setting I got 20 mpg, but when I used the 65hp, I got 15 mpg in the city. My next step is to try the tow tune and see what mpg I get, plus see about the 4" turbo back exhaust. When I used the 65hp setting, the transmission didn't shift as smooth as when it was in the 100hp setting. Any ideas?
Transmission line pressure is the same on both tune for the 65hp and the 100hp. The adaptives might need relearning first but you should see that shifting will improve over the next day after driving.
RE: Re: RE: yes I got it to load
Posted: Sat May 31, 2008 9:41 am
by thomas5853
On the 65hp tune, is the limitations of the 8000 lbs on the towing weight or the GCW?
