Please help, new member with a question.
Tanner
Post by Tanner »
I bought a truck this past weekend that came w/ the diablo u7165. When I plug it in to do a tune it says "your vehicle is not in our database. contact your dealer for a free update. you cal_id is 'vxcf5h5' " what do i do??
The truck is a 2006 f250 powerstroke any suggestions?
kmacicek
RE: Please help, new member with a question.
Post by kmacicek »
what revision number is it
2005 F-350 6.0 CCSB
MBRP 4" Turbo Back
Cat Delete
AIRAID Filter
U7165 DiabloSport GONE
SCT X3
Tanner
Post by Tanner »
It says v8r14. Is that what you are talking about? Thank you for replying!
Tanner
Post by Tanner »
anybody out there?
BIGROC
Post by BIGROC »
Tanner,YOUR CAILID IS NOT SUPPORTED IN THE R14 REVISION.YOU NEED TO UPDATE THE TUNER WITH THE R20 REVISION AND IT SHOULD BE FINE. :D
Tanner
Post by Tanner »
Ok, I will try that as soon as I get the cable. The main thing that I dont understand is why this thing worked in the past for the previous owner. Can you explain why that is? Thanks for the reply! -Tanner
BIGROC
Post by BIGROC »
Tanner,IF THE OWNER HAD IT AT FORD THEY COULD HAVE DONE A REFLASH ON THE PCM AND THE NEW CALID WOULD NOT BE SUPPORTED BY THE R14 REVISION.IF YOU CHECK UNDER THE HOOD,OR ON THE RAD. SUPPORT THEY WOULD HAVE TAGGED IT AT THE FORD DEALER IF THEY REFLASHED IT.
Tanner
Got it working thanks! But not a noticable gain of power!!
Post by Tanner »
I dont see much difference than stock with this thing. What is the deal?
Re: Got it working thanks! But not a noticable gain of powe
Tanner wrote:I dont see much difference than stock with this thing. What is the deal?
So you were able to update it and load the tune?
You should certainly feel the tunes, even if its just the 40hp tow tune.
Tanner
yes I got it to load
Post by Tanner »
and I am on the 65hp tune. It just does not feel any different than before. I thought there was suppost to be a noticable difference. I will drive it a little more this evening and see what I find.
thomas5853
RE: yes I got it to load
Post by thomas5853 »
Do I have to upgrade anything in order to use the 100hp setting?
Yes, we recommend a 4" turbo back exhaust and EGT guages...
thomas5853
So far, when I used the 100hp setting I got 20 mpg, but when I used the 65hp, I got 15 mpg in the city. My next step is to try the tow tune and see what mpg I get, plus see about the 4" turbo back exhaust. When I used the 65hp setting, the transmission didn't shift as smooth as when it was in the 100hp setting. Any ideas?
cole
Re: RE: yes I got it to load
Post by cole »
thomas5853 wrote:So far, when I used the 100hp setting I got 20 mpg, but when I used the 65hp, I got 15 mpg in the city. My next step is to try the tow tune and see what mpg I get, plus see about the 4" turbo back exhaust. When I used the 65hp setting, the transmission didn't shift as smooth as when it was in the 100hp setting. Any ideas?
Transmission line pressure is the same on both tune for the 65hp and the 100hp. The adaptives might need relearning first but you should see that shifting will improve over the next day after driving.
Cole Stevens
thomas5853
RE: Re: RE: yes I got it to load
On the 65hp tune, is the limitations of the 8000 lbs on the towing weight or the GCW?
