Issues updating intune
Posted: Fri Nov 24, 2017 2:31 pm
by nicholas.willoughby
When I tried to use the Ignition Updater I get the device error please call technical support under details it says Device SKU cannot be determined.
I then tried to just double click CD Drive Diablosport, it updated something rebooted the device and now says An unexpected error occured: Tool OEM is missing Parameter name: oem twice. Is there anyway you could help me get this updated?
Tool Version: 1r01h
Firmware Info:
GM Tune Db: 1r01w
DCX Tune Db: 1r01b
Ford Tune Db: 1r01o
GM PID Db: 1r01a
DCX PID Db: 1r01a
FORD PID Db: 1r01b
Application: 1r01h
DTC Db: 1r01a
VIN Db: 1r01c
Info Db: 1r01b
EDIT: Added info.xml
Re: Issues updating intune
Posted: Sun Nov 26, 2017 10:34 am
by rene_1520
i am having the exact same issue :cry:
Posted: Sun Nov 26, 2017 10:54 am
by rene_1520
info
Posted: Sat Dec 02, 2017 12:02 pm
I still need help, normally the support is better but this is disappointing...
Posted: Tue Dec 05, 2017 1:17 pm
nicholas.willoughby wrote:When I tried to use the Ignition Updater I get the device error please call technical support under details it says Device SKU cannot be determined.
Tool Version: 1r01h
Firmware Info:
GM Tune Db: 1r01w
DCX Tune Db: 1r01b
Ford Tune Db: 1r01o
GM PID Db: 1r01a
DCX PID Db: 1r01a
FORD PID Db: 1r01b
Application: 1r01h
DTC Db: 1r01a
VIN Db: 1r01c
Info Db: 1r01b
this device is super old, hasnt been updated in probably 4-5 years?
Need to load the 1r01i file first, then the 1rt03y file, once it imports them inthat order, use the ignition software to update the device.
rene_1520 wrote:i am having the exact same issue :cry:
please post the info.xml file from the intune drive.
Posted: Mon Oct 01, 2018 10:32 am
by Preston5280
Hello
Is there a fix for this? I am having the same issue and need to update my tune to the latest for an emissions test.
Info.xml attached
Any help would be much appreciated.
Posted: Wed Oct 03, 2018 8:57 am
Preston5280 wrote:Hello
Info.xml attached
this device is up to date.
