When I tried to use the Ignition Updater I get the device error please call technical support under details it says Device SKU cannot be determined.
I then tried to just double click CD Drive Diablosport, it updated something rebooted the device and now says An unexpected error occured: Tool OEM is missing Parameter name: oem twice. Is there anyway you could help me get this updated?
Tool Version: 1r01h
Firmware Info:
GM Tune Db: 1r01w
DCX Tune Db: 1r01b
Ford Tune Db: 1r01o
GM PID Db: 1r01a
DCX PID Db: 1r01a
FORD PID Db: 1r01b
Application: 1r01h
DTC Db: 1r01a
VIN Db: 1r01c
Info Db: 1r01b
EDIT: Added info.xml
Issues updating intune
nicholas.willoughby
- info.xml
- (435 Bytes) Downloaded 626 times
Re: Issues updating intune
i am having the exact same issue
nicholas.willoughby
I still need help, normally the support is better but this is disappointing...
this device is super old, hasnt been updated in probably 4-5 years?nicholas.willoughby wrote:When I tried to use the Ignition Updater I get the device error please call technical support under details it says Device SKU cannot be determined.
Tool Version: 1r01h
Firmware Info:
GM Tune Db: 1r01w
DCX Tune Db: 1r01b
Ford Tune Db: 1r01o
GM PID Db: 1r01a
DCX PID Db: 1r01a
FORD PID Db: 1r01b
Application: 1r01h
DTC Db: 1r01a
VIN Db: 1r01c
Info Db: 1r01b
Need to load the 1r01i file first, then the 1rt03y file, once it imports them inthat order, use the ignition software to update the device.
- intune-1r03y.itf
- (1.82 MiB) Downloaded 846 times
- intune-1r01i.itf
- (1.48 MiB) Downloaded 1300 times
please post the info.xml file from the intune drive.rene_1520 wrote:i am having the exact same issue
Preston5280
Hello
Is there a fix for this? I am having the same issue and need to update my tune to the latest for an emissions test.
Info.xml attached
Any help would be much appreciated.
Info.xml attached
- info.xml
- (1.67 KiB) Downloaded 540 times
- ignition error.jpg (280.18 KiB) Viewed 9850 times
this device is up to date.Preston5280 wrote:Hello
Info.xml attached
