Issues updating intune
nicholas.willoughby
Post by nicholas.willoughby »
When I tried to use the Ignition Updater I get the device error please call technical support under details it says Device SKU cannot be determined.
I then tried to just double click CD Drive Diablosport, it updated something rebooted the device and now says An unexpected error occured: Tool OEM is missing Parameter name: oem twice. Is there anyway you could help me get this updated?
Tool Version: 1r01h
Firmware Info:
GM Tune Db: 1r01w
DCX Tune Db: 1r01b
Ford Tune Db: 1r01o
GM PID Db: 1r01a
DCX PID Db: 1r01a
FORD PID Db: 1r01b
Application: 1r01h
DTC Db: 1r01a
VIN Db: 1r01c
Info Db: 1r01b
EDIT: Added info.xml
info.xml
(435 Bytes) Downloaded 629 times
rene_1520
Re: Issues updating intune
Post by rene_1520 »
i am having the exact same issue :cry:
rene_1520
Post by rene_1520 »
info
nicholas.willoughby
I still need help, normally the support is better but this is disappointing...
nicholas.willoughby wrote:When I tried to use the Ignition Updater I get the device error please call technical support under details it says Device SKU cannot be determined.
Tool Version: 1r01h
Firmware Info:
GM Tune Db: 1r01w
DCX Tune Db: 1r01b
Ford Tune Db: 1r01o
GM PID Db: 1r01a
DCX PID Db: 1r01a
FORD PID Db: 1r01b
Application: 1r01h
DTC Db: 1r01a
VIN Db: 1r01c
Info Db: 1r01b
this device is super old, hasnt been updated in probably 4-5 years?
Need to load the 1r01i file first, then the 1rt03y file, once it imports them inthat order, use the ignition software to update the device.
intune-1r03y.itf
(1.82 MiB) Downloaded 849 times
intune-1r01i.itf
(1.48 MiB) Downloaded 1303 times
rene_1520 wrote:i am having the exact same issue :cry:
please post the info.xml file from the intune drive.
Preston5280
Post by Preston5280 »
Hello
Is there a fix for this? I am having the same issue and need to update my tune to the latest for an emissions test.
Info.xml attached
Any help would be much appreciated.
info.xml
(1.67 KiB) Downloaded 544 times
ignition error.jpg (280.18 KiB) Viewed 9879 times
Preston5280 wrote:Hello
Info.xml attached
this device is up to date.
