Need PCM calibration following truck recall
Posted: Sun Jul 01, 2018 11:19 am
by P40Hawk
2014 Ram 2500 power wagon. I returned the truck to stock before the recall appointment at the dealership. Once I returned and tried to reinstall the diablo tune it is telling me the PCM needs to be recalibrated. I tried to update the handheld but no updates are available. attached is the .xml file.
One of the recalls was to update the PCM from 68153865AG to 68153865AK If that helps.
Re: Need PCM calibration following truck recall
Posted: Mon Jul 02, 2018 12:47 pm
connect the device to a pc and run the ignition updater program and it will download the file you need then you can load it to the vehicle then tune it.
Posted: Mon Jul 02, 2018 9:36 pm
by P40Hawk
Thanks Mike,
The auto Updater worked this time. However, there was an error during the PCM recalibration and it failed. Now the handheld is in recovery mode. What do you want me to do now? I have tried it three time with the same result. It progresses through 100% then circle of death until it states an error has occurred.
