6.1 Swap
Dredagiant14
6.1 Swap
So I got a 6.1 swapped into a 5.7 charger rt and it started up with no problem. Right now I have a 5.7 diablo tune on it with the mds turned off. Can My mechanic needs to take it to a exhaust shop to connect everything. I was planning on taking it to dodge right after that to get it reflashed to a 6.1 pcm. Should I be fine with that 5.7 tune to take it to the muffler shop and dodge? I also remember have to get my 5.7 force calibrated to get my stock tune back as it was lost when I had to get a new tuner. Would I be able to do that instead of going to dodge for the stock 6.1 file? Thank you!
Re: 6.1 Swap
we cant trick it to load a 6.1 file so dealer is best option if they are able to do this.
You'll need a custom tune once that's done to fix the displacement scalar so you wont have constant ABS lights.
