Page 1 of 6
Will not save the original tune
Posted: Fri Apr 11, 2008 5:30 pm
by rattler
Just got my tuner and it will not save my original tune, what could be the problem, or what can I do to correct the problem
RE: Will not save the original tune
Posted: Mon Apr 14, 2008 2:54 pm
Is this a 7.3?
Sounds like a chip is in there, remove it and all is well...
Posted: Mon Apr 14, 2008 5:14 pm
by rattler
No this is a 6.0L in a 2003 F250, Every time I try to load a program it comes back saying could not save original program with a -10, just had the pcm flashed at the ford dealership.still does the same thing. I have a u1765 programmer. What do I need to do.
Posted: Mon Apr 14, 2008 5:46 pm
Not sure about this...what revision is on the Predator?
Plug the tool in and go to options/troubleshooting/show calid and tell me what it says there as well.
Posted: Mon Apr 14, 2008 5:57 pm
by rattler
calid says VXAP2N2HEX
Posted: Mon Apr 14, 2008 11:22 pm
by jiffjar
i am having the same problem..just got the tuner today and it will not save stock tune...i have the edge chip on my 03 f250 6.0 but i dissconected it to upload the tune, also aftermarket sterio system unpluged...what could the problem be? any info would be a big help..thanks
Posted: Tue Apr 15, 2008 10:10 am
Are you sure the other module is fully disconnected?
Does it start to read and then fail?
What revision is on this tool?
rattler wrote:calid says VXAP2N2HEX
revision?
Posted: Tue Apr 15, 2008 11:20 am
by jiffjar
revision is V.9r03
calid is VXAP2N2HEX
i had my truck reflashed at ford today. the problem remains the same...sugestions?
Posted: Tue Apr 15, 2008 11:22 am
by jiffjar
other module is fully out of the loop, and yes it starts to read get to only 0 of 1% and then fails.
programmer problem
Posted: Tue Apr 15, 2008 12:50 pm
by rattler
Version: V.9r03, serial: 009f90 hardware: univ_rev2, so now what do I do to fix this problem
programmer problem
Posted: Tue Apr 15, 2008 12:51 pm
by rattler
NEED HELP TO SOLVE THIS PROBLEM
Posted: Tue Apr 15, 2008 12:55 pm
rattler wrote:No this is a 6.0L in a 2003 F250, Every time I try to load a program it comes back saying could not save original program with a -10, just had the pcm flashed at the ford dealership.still does the same thing. I have a u1765 programmer. What do I need to do.
The -10 is telling us the PCM does not have a stock tune.
I'd try reflashing the truck back to stock at the dealer.
Posted: Tue Apr 15, 2008 12:56 pm
jiffjar wrote:other module is fully out of the loop, and yes it starts to read get to only 0 of 1% and then fails.
It would appear that your Edge device has not come off cleanly...if the PCM is fully stock, the Predator will read it.
programmer problem
Posted: Tue Apr 15, 2008 1:04 pm
by rattler
tHAT IS JIFFJAR PROBLEM, RATTLER HAS NOITHING ON THE PCM AND PCM IS CLEAN STILL WILL NOT SAVE TUNE, SO IF THERE IS NO CURE AND CAN NOT BE FIX THEN THE DIABLOSPORT WILL NOT WORK AND I CAN GET A REFUND, I WOULD RATHER SEE IT WORKING THAN RETURNI IT, CAN WE FIND A CURE.
