07 nbs torque mgmt update?
fastfreddy525
Post by fastfreddy525 »
any idea when you will have the updates available for the 07 nbs 6.0 max trucks for torque mgmt and trans adjustments. its been a long time waiting for them ,since i bought my predator last year ,now bully dog has come out with a gm gas tuner with t.m and trans adjustment, if they have it ,why werent you guys the first to introduce that in your tunes ,you guys have had the gm tuners alot longer than they have, all they have had is stuff for diesels,why is it taking so long.
trucknSW
Post by trucknSW »
YEA!!!
rap-1
Post by rap-1 »
How about doing somthing about the NNBS tow/haul? It does nothing,but show a light on the dash,no raised rpm's,shift points....nothing.Please help in that dept.Thank,you.
CANUCKPREDATOR
Post by CANUCKPREDATOR »
If you don't have a load on the truck, Tow/Haul doesn't do much. Pull a trailer or put a heavy load in the box, your shift points are bumped up at least 250 rpm (maybe more, I only pulled a small trailer with 1 ATV)
rap-1
Post by rap-1 »
CANUCKPREDATOR wrote:If you don't have a load on the truck, Tow/Haul doesn't do much. Pull a trailer or put a heavy load in the box, your shift points are bumped up at least 250 rpm (maybe more, I only pulled a small trailer with 1 ATV)
I pull a 23ft toy hauler,and i dont see any of that.Pulls the same in tow/haul,as it does w/out t/h,same rpm shifts,what happend to the raised rpm??? trying to get 6500 ibs trailer moving off idol,when turning or moving slowly is hard.my 99 5.3 had raised rpm's.
08_Z71
Post by 08_Z71 »
rap-1 wrote:I pull a 23ft toy hauler,and i dont see any of that.Pulls the same in tow/haul,as it does w/out t/h,same rpm shifts,what happend to the raised rpm??? trying to get 6500 ibs trailer moving off idol,when turning or moving slowly is hard.my 99 5.3 had raised rpm's.
Somethings wrong somewhere there. Every once in a while I'll use the t/h mode on my truck when towing my bass boat ( 1800# +/- ) and the shift rpm's are definitely higher. (93 octane tune / DoD off)
Don
08 Silverado 1500 Ext Cab - 4WD - 5.3 - Z71 - Magnaflow - K&N CAI - U7194
CANUCKPREDATOR
My 800lbs aluminum sled trailer and 400lbs ATV are enough of a load to make things change. Maybe you should have it checked out under warranty in case there is something wrong.
