Intune logging weird PIDs
bgdawgjr
Post by bgdawgjr »
I believe I have an Intune i2 and I seem to be having problems logging the proper PIDs for tuning purposes. I have gone through the handheld and chose the PIDs I need to log, but when I load the .log file to the computer, it seems as though only a few that I chose actually saved and there are a bunch of other random ones that don't make sense. Also I cannot seem to find any LTFT for either bank whether I use the handheld alone or connect through a laptop. Live view of both 1/1 and 2/1 LTFT show either 0% or 100%, with no changes what so ever. I can however connect with my OBD scan tool and view live data and pull up all those parameters without any issue.
Is the something wrong with my handheld that it needs to be reset? Possibly an update that it did not perform on its own?
Vehicle is a 2007 Magnum R/T, I have attached my info.xml file and the latest log file that I saved. The PIDs chosen when recording were listed by Johan in his "PIDs to log for your tuner" post. The results of the saved log file don't seem to match at all.
Appreciate any help that may come my way.
Re: Intune logging weird PIDs
this is an old 1000, not i2. Not sure whats happening but we haven't offered updates for this device in years now unfortunately.
id try restoring the default pids and see if you get what you need.
