https://youtu.be/owaQ33DzcWU
Bypass cable installation Charger/Challenger Video
Re: Bypass cable installation Charger/Challenger Video
Going to order mine soon 2018 RT Challenger. The Video I saw showed the bypass cable being installed in the trunk. I opened mine up and have access to both green and white busses in the trunk. Can I still install the bypass cable that way or has something changed?
trunk is not used any longer, current cable connects up front at the OBDII port.
Is the Video wrong?
Your Video says the connector buss is located behind the OBD2 port. Yet it looks like its being connected under the passenger side kick panel. I just ordered mine and now I’m confused. Please clarify!
My T2 / PCM will arrive tomorrow, please clarify why the Video of the bypass cable install is saying the connector to plug into is located directly behind the ODB2 connector. This can not be right, unless Im missing something.
