Gateway Bypass Cable Video Wrong 2018/19
Posted: Thu Jun 20, 2019 12:26 pm
by tdjacw
https://youtu.be/owaQ33DzcWU
This Video states the Green Module is located directly behind the OBD2 port. However the Video shows it under the passenger kick panel.
They need to fix this very confusion. Even the instructions I received stated this.
Re: Gateway Bypass Cable Video Wrong 2018/19
Posted: Sat Jun 22, 2019 11:46 am
by tdjacw
So no answer from customer support about the gateway bypass cable install Video and instructions being wrong. However I just installed the cable and PCM and can confirm the Video/instructions are incorrect. The green buss connector is located under the glove box NOT DIRECTLY BEHIND THE OBD2 port. This could be really confusing to folks. They really need to correct this as every time I watched the Video I kept second guessing myself.
Posted: Mon Jun 24, 2019 9:18 am
Looking into why the vid is different.
