I own an I-1000 for my 2006 Jeep Grand Cherokee 5.7l Hemi
My SN: 'CIDWH8D-1'
sw_rev='1r04j' svn='9115'/>
<registration sn='CIDWH8D-1' status='1'/>
<cal_id PCM='56044762AJ' CM1='56044757AGA'/>
<restore id='0' vin='1J8HCE8286Y150938' bc='10'/>
I wanted to change the Setup, my I-1000 goes in recovery-Mode, and I failed to Restore my Backup back again on my Jeep.
I changed on my Car only the Valvebody with Seleonoid Control Unit on my Gearbox, because my Gearbox chrashed.
What do I have to do to go off Recoverymode to reset my Jeep to Original Backup.
I made the info.xml already
My Reset Key is:
B3387A
4D6268
6B4EAB
39D4FD
2B88B7
Thanks!
Regards
Winni Haves
Germany
I-1000 in recovery Mode, no original Backflash possible
VinceGC345
Re: I-1000 in recovery Mode, no original Backflash possible
you dont want to reset it.
does the vehicle still start and run properly?
VinceGC345
Yes it runs!
But my I-1000 is now in Recovery Mode, i can not Restore my Original Backup, to choose an other Setup.
What do i have to do now?
Thanks!
Regards
Thanks!
Regards
VinceGC345
Hello!mikel wrote:you dont want to reset it.
Yes my Car Runs!
But i Can not use my I-1000
Recovery Mode
What do i have to do?
Best option would be to give us a call with the tool powered up so we can reset it and make sure its ok.
VinceGC345
Thank You!
I called and it Works!
Regards from Germany
