Hi!
I have a 2013 Charger 3.6 and 8 speed (8HP45) and have been using my intune for years now with no problems. I recently removed the stock 2.65 rear differential and installed a 3.07. When I attempt to change the gear ratio with the intune I get the following: error reading "axle ratio" parameter. I have updated the tuner and reached out to Diablosport technical and was told that since the tool is failing there is nothing to be done.
I've read on some forums where guys just seapped in gears and let the computer learn, but that doesn't work on my car. As soon as I go above 55mph or sustain below 50 for a long period I get a check engine light and the transmission goes into limp mode. I'm getting codes: P215C00 output shaft speed / wheel speed correlation, and P1DB600 vehicle speed signal performance.
I use my scanner to view live data and verify that when the wheels and speedo are showing 50mph the shaft speed is showing 56 thus tripping the code. I'm trying to find a way around this without having to put the original gears in. Is this just a problem with my intune, or does the intune itself not truly allow gear changes on a 2013 3.6 8 speed?
Thanks.
inTune Problem
Jump to
- Welcome to DiabloSport
- ↳ Announcements
- ↳ Test Vehicles Wanted
- i2/i3 Technical discussion
- ↳ i2/i3 for Dodge, Chrysler, Jeep and Ram
- ↳ i2/i3 for Ford vehicles
- ↳ i2/i3 for GM vehicles
- ↳ Ignition updater
- Trinity 2
- ↳ T2 for Dodge/Chrysler/Jeep/Ram
- ↳ T2 for Ford
- ↳ T2 for GM
- ↳ Trinity MX monitor
- PredatorX
- ↳ PredatorX for GM vehicles
- ↳ PredatorX for Dodge/Ram vehicles
- ↳ PredatorX for Ford vehicles
- ↳ PredatorX Requests and Feedback
- Predator 2 Support
- ↳ Predator 2 for Chrysler/Dodge/Jeep/Ram
- ↳ Predator 2 for GM
- ↳ Predator 2 for Ford
- Pulsar
- ↳ Pulsar for Ram
- Trinity Technical Discussion
- ↳ General Trinity
- ↳ Trinity Ford Gas
- ↳ Trinity Ford Diesel
- ↳ Trinity Dodge Gas
- ↳ Trinity Dodge Diesel
- ↳ Trinity GM Gas
- ↳ Trinity GM Diesel
- inTune i-1000 Technical Discussion
- ↳ General inTune forum
- ↳ Auto Updater/PC related issues
- ↳ Mac/Non Windows based issues
- ↳ inTune DCX (i-1000-DCX)
- (Legacy) Predator Technical Discussion
- ↳ Predator Ford Gas
- ↳ Predator Ford Diesel
- ↳ Predator Dodge Gas
- ↳ Predator Dodge Diesel
- ↳ Predator GM Gas
- ↳ Predator GM Diesel
- General Technical Support
- ↳ DataViewer/DV2
- ↳ General Support
- ↳ Custom Tune Support
- ↳ DeltaChip
- ↳ MAF.i.a
- ↳ DSDL
- ↳ PowerPuck/Extreme PowerPuck
- ↳ CatchCan Support
- DiabloSport Community
- ↳ General Questions
- ↳ Lounge
- ↳ Suggestion Box
- ↳ Future Product Requests
